Hi folks
I bought a Zeblaze Blitz Smartwatch 1/2 year ago.
Now the battery is not working anymore. Do anyone know where I can buy a replace product battery?
The size is: 27,0 x 22,0 x 6,0 mm.
Anyone knows a address to buy a batterey?
thanx
Jo
Hi folks
thanx
Jo
Feb 2, 2017 17:29:31 GMT 1 jo said:
Hi folksI bought a Zeblaze Blitz Smartwatch 1/2 year ago.
The size is: 27,0 x 22,0 x 6,0 mm.Anyone knows a address to buy a batterey?
thanx
Jo
Were u able to get the replacement battery?
Hello folks (sorry for mistakes, I’m french). I search a new battery for my zeblaze blitz but I’ can’t find it anywhere. Can you help me please, thanx.
Nov 22, 2018 19:44:50 GMT 1 axelvet said:
Hello, thanx for the answer. Unfortunately each link is dead … and I’ve search in the site and didn’t find what I need.
Nov 23, 2018 12:47:27 GMT 1 axelvet said:
Hello, thanx for the answer. Unfortunately each link is dead ... and I've search in the site and didn't find what I need.
Hello, the size of the battery is 28 mm, 30 mm,6 mm as you can see on the video (at the 15th minute). And the capacity is more or less 480 mah. There is a special plug too.
Nov 23, 2018 22:08:10 GMT 1 axelvet said:
www.aliexpress.com/item/Free-Shipping-3-7V-400mAH-602525-602626-PLIB-polymer-lithium-ion-Li-ion-battery-for-SMART/32828493530.html?spm=2114.search0104.3.63.3ef411a3NvSbBL&ws_ab_test=searchweb0_0,searchweb201602_2_10065_10068_319_5735015_317_5734915_10696_10084_453_10924_454_10083_10618_10920_10921_10307_10922_537_536_10059_10884_10887_100031_5735215_321_322_10103_5735115,searchweb201603_51,ppcSwitch_0&algo_expid=4cf575c2-ea91-4603-99f4-2ecff1e282c3-8&algo_pvid=4cf575c2-ea91-4603-99f4-2ecff1e282c3
www.aliexpress.com/item/100-Original-KW88-Battery-350mAh-high-quality-battery-For-KW88-KW99-Smart-watch-replacement-3-8v/32894459692.html?spm=2114.search0104.3.2.3ef411a3NvSbBL&ws_ab_test=searchweb0_0,searchweb201602_2_10065_10068_319_5735015_317_5734915_10696_10084_453_10924_454_10083_10618_10920_10921_10307_10922_537_536_10059_10884_10887_100031_5735215_321_322_10103_5735115,searchweb201603_51,ppcSwitch_0&algo_expid=4cf575c2-ea91-4603-99f4-2ecff1e282c3-0&algo_pvid=4cf575c2-ea91-4603-99f4-2ecff1e282c3
Hello, thanks a lot for your answer. I ask if they have what I search. I hope they can help me.
Best regards.
Possibly too late - I’ve just replaced the battery in my Zeblaze Blitz.
I bought a 582728 500mAh battery (that’s the size code of the original, I reckon you could get something slightly larger in there).
Specifically I bought - www.aliexpress.com/item/Fikida-3-7V-500mAh-Rechargeable-li-Polymer-Li-ion-Battery-For-Q50-G700S-K92-G36-Y3/32918713151.html but I think any battery with that size code should work.
I wasn’t sure which battery controller to use, but on the basis that the new one had 2 connectors and the old one had 3 I decided to switch the board entirely.
To do that - unpeel the yellow tape and cut off the old battery, making sure to leave plenty of metal tab attached to the old board.
Use a soldering iron to remove the new battery from its control board.
Solder the battery tabs from the new battery to the tabs attached to the old board (the spacing is slightly different but there’s enough overlap). Make sure they’re the same way round as before! (the battery has a + and - on the same side as the tabs)
Put watch back together
My Blitz has gone from not even turning on with power connected to working fine again.
thanks for sharing i wish you would have done a video about the proccess:)
