Try this link:-https://drive.google.com/file/d/18-yJhtxm7jSO0t7hqtJcTIXR3nxVK25V/view?usp=sharing
he said it was the pro version though, but I guess it should work to only flash the userdata partition
@Elnemr, youâll need sp flash tools to flash it, and as I said try first to only flash the userdata partition. sp flash tools is available here: https://spflashtools.com/
And the setting you changed is called âSimulate secondary displaysâ and itâs in the developer settings, not the display settings
i cant fix the problem until now
can any one help me with methods
Iâll assume my previous post didnât explain well enough what to do so lets try this:
- download sp flash tools if you havenât already
- download and unzip this: https://drive.google.com/file/d/1zQcbO-bzKfTOidxpUTM3Lt21Sh9iXuH6/view?usp=sharing
- open sp flash tools
- press the âchooseâ button on the line where it says âscatter-loading fileâ
- choose the file âMT6739_Android_scatter.txtâ
- make sure it is in âdownload onlyâ mode
- press download
- connect the watch while it is off
- wait for a green check mark
- done
