Bought a Kospet Optimus Prime to run an application called xdrip plus that works as a continuous glucose monitor (CGM). I can get the widgets and app to work on the watch but the watchface that goes with android wear, I cant seem to get onto the watch.
GitHub xdrip+ repository: https://github.com/StephenBlackWasAlreadyTaken/NightWatch
Full Android watches do not support Android Wear
Yeah that is why I am posing the question. I may have a solution from the amazing work of FREDERIKWAGNER311991. Can post later if I get it to work out
Any progress on this? Doesn’t seem any diabetics use a full android watch. Short of a widget through nova launcher I can’t find anything that works.
Android Wear apps are supposed to communicate with the app running on the phone. So, even if you’re able to make the watch app run on our Full Android Watches, it will not communicate. Or, you will have to modify the source code to rework everything.
