[Unlocking LTE Bands on MTK devices](https://forum.xda-developers.com/showpost.php?p=83167609&postcount=18)
Has anyone here tried this? Its pretty late my time so Ill be trying to do it once i gets some sleep. But let me know if anyone else tries success or fail. Please post screenshots of results if possible. Thanks.
I haven’t heard of that yet. Why don’t you test it and share your em results with us?
So i may need some help with this. Here is the full block list with names. (LEMFO LEM T)
https://del.dog/lupifuhocr
The problem that im having is that the nvram comes up as read only file system, even though im using “su” command. Im assuming that i would need to make the partition rw in order to pull the partition from my device to my computer to try and edit. Im using the following command to pull MAX:/ # dd if=/dev/block/mmcblk0p20 of=/nvram.bin
dd: /nvram.bin: Read-only file system
Any help would be appreciated. Thanks
you can use the readback section of sp flash tools
