X5 14/04/16 (link)
Changes- unknown
Compatible with other watches- untested
Notes- none
Bug List
Clockskin Engine Bugs
Firmware Bugs
1- Google syncs no longer work over a 2G connection. (2G data still works though)
2- Stock keyboard will not use Google voice search as an input method
3- Stock keyboard uses “Speech Keyboard” for voice input which never connects to server
Apps Bugs
1- One can start a timer on the stock clock app via Google voice command but cannot access it as everything except “Alarms” is locked out.
Phone Bugs
1- (When used as a standalone with simcard inside) Sometimes, in the uncovered areas or with poor signal, the phone freezes. The signal streng indicator freeze, and the network search does not work. To reset you need to turn on and off airplane mode or power cycle the phone. This happens with both 2g and 3g network.
X5 24/05/16 (link)
Changes- unknown
Notes- none
Bug List
Firmware Bugs
1- Google syncs do not work over a 2G connection while browser works fine
4- BT turning itself off for no good reason is still there.
Apps Bugs
1- Weather doesn’t update
Phone Bugs
1- Cellular bug (random disconnects) still persists making stable standalone usage impossible.
