I have an X3+ which keeps forgetting my paired devices on bluetooth, so that I have to manually go and add them again. This obviously stops M2D from working when it happens, which I’d say is 1-2 or more times a week.
Also, the connection keeps dropping out all the time, I’m constantly feeling the watch and phone buzz (on wrist and in pocket, so no more than 50cm from each other usually, albeit through my body some of that time). Is this par for the course with this watch?
Finally, along with my designated bluetooth device name, there is another one called “WATCH-NC” which is definitely being generated by the watch, as it disappears when I turn it off. I can see this simultaneously from other devices, but also from the watch itself when it searches for connections. It’s almost as though there’s a whole separate bluetooth radio in there, or that it has been partition as you can do on WiFi to provide a second virtual radio.
All in all, lots of bluetooth oddnesses!
Apr 9, 2017 20:03:38 GMT 1 schlimig said:
I have an X3+ which keeps forgetting my paired devices on bluetooth, so that I have to manually go and add them again. This obviously stops M2D from working when it happens, which I'd say is 1-2 or more times a week.
the watch’s name appears twice one is for ios, about bt that is not normal i do’nt have this kind of problem but i’ve reseted the watch not once and flashed it with the FW twice or more:)
