I have an Ourtime X200 for several months… I wasn’t happy with the RF… Bluetooth kept reconnecting…and worked only well in a distance of centimeters from my phone… Wifi similar… I have tried many things… and than… it went into an endless bootloop…I read about new firmware so tried to find x200 firmware… I couldn’t find it
Then here I read that The Les 1 and Thor are the same watches…so tried to upload this firmware…worked!! But… the screen is correct but the touchscreen is rotated 90 degrees so hotspots don’t line up with the gui.
What can I do…?
The original ourtime firmware is not to be found… I have tried many otherones but all with rotated touchscreens… how can I correct it.
no worries, ok, i’ve checked and the only available firmwares for these watch it the thor and les1 ones, try to check with the forum of open watch project see how they can help you with the problem.
can you tell me which link did you use and which sp f.tool version did you use? lets check this first before.
Hi Sonia,
Ive got it working again… its not the Les 1 or Thor… but the Diggro Di01… Installed the firmware from their website and worked instant.
Hope this helps other people
Problem with the RF remains but i guess its a hardware problem.
sorry, but not sure we have a firmware for this watch, but i know some have had issue with the watch, try searching for info on the forum just write the name of the watch and you'll get it.
