Does anyone know where it is? Found what I’m looking for for kospet prime but not for lem13.
Hey Sonia, It is on the home page under Lemfo products. I don’t see a listing under this category for the Lem 13 or anything in the firmware link. I don’t think anyone has requested information about this watch. Everybody is probably out to lunch.
Thanks, I also contsct lemfo and the seller, it is a great watch with amazing battery life , it and the kospet prime with.full heavy usage I get more than 20hrs, LTE , GPS, always on and BT for few hrs and I’ve modified all apps usage that they always awake even when screen off.
Hi Sonia,
It seems we don’t have a lem13 section, but probably @pablo11 can help you on this one.
Hello stranger
I will send you a pm
Basically we did not get the LEM13.
If you need the firmware for it I will get it, but it has not changed since the version you have I expect…
It is basically an A7.1.1 version of the LEM14 which is Android 10.
Anyway, let me know what you need
I will post the Android 7.1.1 firmware for it but we don’t support it.
Give me a few minutes and I will post it
Here it is
THANKS guys.
Guys if now after I’ve flashed the lem13 FW and I want to flash the kospet prime the only thing I don’t flash is the preloader , right? I don’t want to lose the imei😪 I know how to fix it but I preferI don’t😊.
No you can’t flash KC10 (Prime) firmware on to a DM28 (LEM13) without having problems…
Many different drivers involved.
Sorry @sonia_sophie_ataunna
Yep, noticed it doesn’t boot up
Hello, tell me if you can flash lemfo lem13
if possible, tell me how to do it
thanks
I flashed it with it’s firmware and it works fine.
with the use of sp flash tools (v5, not v6): https://spflashtools.com/
you can use either “firmware upgrade” or “download only”
Are you still needing to flash your Prime or is it the LEM 13?
My kospet is good:) and the lem13 also good thanks,to you.
I am very happy to hear that
Let me know if you need anything.
Do you still need help?
