For me I chose the Bluedio T-elf 2 They are on the way to my house. Can’t What about everyone else?
I have two pair because one only lasts about 3 hours on a full charge:
I prefer the Blitzwolf because I think it sounds better (but I’m no audiophile), blocks out external sounds better, and has next/previous track which the Airdots lacks.
Neither has bass balance exactly how I like it so I installed this equalizer - it’s free and works well on watches:
Both have some connection issues when I’m out walking with the watch on my left arm. When it’s on my right arm it’s much better. I assume that’s because the right earbud is the main one,
EDIT I should add that the above is my experience with a Kospet Prime & Optimus Pro. I don’t have a Lem T (yet).
Sabbat E12 (extra BASS)
bone conduction earbuds… total classy and doesn’t make you deaf to your surroundings
I use these:
and
TWS JHO-A9
Great earbuds, master/slave switching compatible, great battery life and good sound and noise cancellation.
You know i never thought about that with my earbuds. You described the exact issue Im having with them, but i never thought to change to my right arm. Thanks!!!
this is a common issue i have had with all these watches . I once had a $5 one pierce earbud that i had in my left ear with my watch on my left arm that worked better than more expensive types ?
its crazy how that works. It makes you wonder if their coding is not “clean” when it comes to bluetooth. I switched to the FIIL t1x, spent only 50 dollars, love them to death. I get better signal with them, but from time to time, i still get that same issue. Like i said, i wonder if the coding for the bluetooth capability is lacking a bit.
I alternately use two pairs
- Huawei Stereo Xsport (AM61)
- Honor Choice True
