Hi
I am having this problem that watchfaces that show weather information such as temperature and cloudcoverage are showing information from some other place on earth. I wouldn’t mind if the weather would follow my watch 16 deg at night to 26 deg C during the day here in Iceland but unfortunately that is not the case.
The weatherapps I have are showing my local weather and the map app show my location. Where do I adjust the watchface to the local weather?
Aug 20, 2018 15:46:43 GMT 1 icebear said:
Hi
just checked with the i7 which is the same as the lem7 and thor4 and it works fine if you are having issues try and use Eric’s launcher and see if the watchfaces work well with it.
Actually I was using Erics launcher and everything seemed fine except I could not activate data on 4g and switching DPI a few times always crashed the launcher. Until I opened a watchface with weather information, then I noticed it was wrong. But just now I was changing DPI and Eric’s launcher crashed and the watch started standard launcher. A lot of ‘ding’ and vibration and notifications began pouring in. Was able to switch to 4G and the weather information is correct now! Must do some investigation to see if the launcher is the problem.
icebear
it better to ask Eric on his thread, it should have worked well.
ricktop
I've found a big bug in Android OS that was crashing my launcher, maybe it explains some of what you see. I'll publish 2.6.1 in a few days.
Until then a reboot usually put everything right.
ricktop After the latest crash I cant start the Universal launcher. Home app shows only standard launcher. Play store shows it is installed but don’t know how to restart except uninstalling and installing again?
Ok uninstalled and installed again. Found now that the skin preference was set on Paris France. Set it to Reykjavík Iceland (as before) and the weather information now changed and is now OK.
Can’t set the ‘Wrist turn on timeout’, it is obscured by Google Widget on/off button
Problem cannot be solves with Dpi button ?
