Lemfo lem x watch faces is it compatible with zeblaze thor 4 pro in stock launcher?
I dont fully understand your question . However most watch faces work with most watches . Obviously the Lem x cuts off the bottom of each face due to its flat tyre as it is called . You cannot remove the stock watch faces from one watch and put on the other
