Wakeup gesture clockskin no launcher (save more battery)
I found a new solution about wake up gesture clockskin, using the “shake” app in the playstore, you can instantly see the default clockskin kw88 without using the launcher and save more battery. I’ve tried a lot of shake to wake up apps but this app is what I think is best. the privilege of this application we can configure the sensitivity of vibration, I tried in the value 10 so as not to often light up when the hand moves. the screen lights up only when there is a hard wobble.
download link below
play.google.com/store/apps/details?id=com.adl.appshaker
See Video :
Interesting app. Specially that sensitivity configuration part
I don’t know if you are aware but I think that since June this year built in wake on wrist gesture (aka taishou or screen on rising) shows chosen clock skin (and not that ugly digital one).
Oh really? sorry because my kw88 is still updated in March, so I do not know. can you give stockrom in june? but is there any feature set the sensitivity of screen on rising?
Update : after using the shake app and without launcher, I can use kw88 from 7 am-12pm (approx 17hours) without touching the charger at all. with normal use ie little browsing & chatting via wifi as well as watching the clock rather often
Can you explain better your configs? Did you use the simple, advanced or pro settings? wich value did you use in sensitive? I'm trying to config it... but istill not happ with the results.
Sept 23, 2017 3:52:26 GMT 1 arzon said:
Sept 22, 2017 23:16:10 GMT 1 ogabriel said:
I use "simple" and "active when screen is off" config, the result depends on the use, i use a little chat & browsing but often see the clock.
use the sensitivity is not too high eg in the numbers 10 or 11 so not too often the screen is on
You can find it in here: /thread/18/kw88-firmware
App is not working on Q7/S1 parser eror
