Wake screen sensor, does not work properly, almost never. Does anyone have the problem with the “Zebleze Thor 4” Smartwatch?
Does any user have a solution?
Firmware I have 2 times already reinstalled
Phone reset several times
That’s such a bad clock
Battery discharges constantly, without use.
Sensors do not go right
This forum is always offered as an aid, but nothing comes from the company itself!
If
battery would hold better or root would be possible, and sensor would
work properly, it would be a great watch, but only worth about 50 €!
I am thinking that one of the power saving options in the firmware is not helping the wake up gesture.
I have been testing with “DuraSpeed” disabled and it seems better.
Could just be a placebo effect… Just have to keep trying to find the cause.
Auto Bluetooth (Solar Wooden Robot) Thats cool safe battery Auto OFF ON
Douple Tap Screen On and Off (not always in use)
Swifly Switch - Sidebars (Best Battery Consumption Low) Quick Shortcuts
Floating Toolbox (best for the clock) Quick shortcuts
Phone To Tablet Remote (Deezer control over the clock)
Watch Droid Phone and Watch Droid Assistant (better than WiiWatch2)
HeartRateOnTop (Top
HeartRateOnTop (Top
How long is twice as long? Are we talking 2 days or a few hours?
HeartRateOnTop (Top
install Magisk via TWRP
a. download Magisk.zip from here: github.com/topjohnwu/Magisk/releases
b. put it on /sdcard
c. reboot to TWRP (or do a+b) before you doing 1.)
d. selecet in TWRP InstallZIP and select Magisk.zip from /sdcard
next enable in Watch Settings/AboutWatch/DeveloperSettings/USB Debuging (i dont have watch in hand, maybe is DeveloperSetting in another part of Settings)
then to recovery is command:
adb reboot recovery
for putting file to sdcard
adb push file_on_pc /sdcard/
for get file from sdcard to actual directory on pc/commandline (this is dot on end)
adb pull /sdcard/file .
of-course, you can put/get file via MTP, you must enable it:
go to Settings/Connect/USB and change to “Transfer Files” can be change only if USB cable connected, and is need repeat whenever you connect it again…
Sept 24, 2018 9:25:20 GMT 1regitllams said: i've done to install twrp on my thor 4. But when i try to install Magisk, i don't know how to reboot to twrp. How can i do for this?
Sept 24, 2018 11:54:56 GMT 1regitllams said: Finally i reboot to twrp and install magisk.zip successfully, but the command is adb reboot recovery (without character "-"). Thank K3dAr
you right, sorry :-) reboot-recovery is parameter for fastboot (if you in downloader/bootloader mode), not adb
Now i have problem, when i reboot thor 4, it in recovery mode and can not escape even reboot. I try by holding both power and back button but don’t work. I found some forum but nothing effect. How can i fix it
Sept 25, 2018 1:43:11 GMT 1regitllams said: Now i have problem, when i reboot thor 4, it in recovery mode and can not escape even reboot. I try by holding both power and back button but don't work. I found some forum but nothing effect. How can i fix it
Thanks for the procedure however, it is lil difficult to follow
I have a zeblaze thor 5 dual and i have issues with the wake to rise
it works 3 out of 5 times when i rise to wak it up
also it has 2 seconds delay
Can i use the ROM for zeblaze thor 4 for thor 5 as well
Also a step by step documentation on this will be helpful as it is the first tine for me to flash a watch
The Screen on Raising option is set with a quick delay time, for you to check the time. To long a delay will result in a lot of battery use, which is why it was changed to about 2 seconds. If you want longer to view the screen just tap the screen and it will revert, to your time setting in display.
