Vwar Nebula X Android 11 Smartwatch
It reminds me of my first moderators sample watch i tested. The Lemfo Lem11. Amazing solid hardware but the screen was so small it was useless. This looks the opposite with a huge screen that would certainly get some looks should you wear it
Edit - just ordered one for £ 72.
Hi guys,
Could not resists and ordered one. Should be here any days now.
I got plans for this to run my Rayban Meta glasses. That is of course if it runs android 11.
Another nice big screen on this 8.1 X11.
However, like all the others, once 3G is gone it probably can’t use VoLTE :frowning:
Mine will be with me tuesday. I’ll report on the specs
It would be great if you can get this to work on VoLTE.
Really interested to hear how you get on.
If it even has the volte switch in Sim card settings it will be interesting :+1:
Recieved S998 today which is the same as the Nebula X. Early days but i can confirm the following -
A11
MTK chipset ( appears to be fake / qualcomm) - tbc
Battery 1000mah
Google apps pre installed / working and syncing
USB C working
Gps working fine
Customized clockskins work with universal launcher only
Developer mode accessible
No connectivity issues
Great as a pocket watch
Watchdroid works fine
Menu and options endless
Build quality average ( all plastic )
So far everything works ( i’ll update this )
Photo’s to follow
Thanks mate.
Can you get the HW info output?
Be nice to see exactly what’s in there :+1:
I’m thinking it is actually A8.1 and faked to look like A11.
Especially since there is no A11 available for MTK.
I would be pleased to hear that I am wrong and it’s all good :crossed_fingers::crossed_fingers:
Morning
MAZE_SPEED_PGDWatch_Q668.pdf (47.8 KB)
What do you think ?
Looks very small on the wrist :grin:
Looking at the HW info report, it has to be false because A11 can’t run on the M6739 soc…
They have done a much better job than the Apple clones to disguise it, but I can’t see how it could be real.
I’ll ask around.
More important is whether it can connect to volte services if all others have been disabled.
Thanks mate :+1:
Interesting. Disable what regarding Volte ?
Need to install MTK engineering mode shortcut and enabled development options etc.
Once you have access, you can disable everything apart from LTE and then test phone calls :+1:
Usually, you can use LTE for data without problem.
But cannot make voice calls once 3G etc is disabled.
Another thing that makes all the difference is if your service provider makes checks regarding what is suitable to access their Volte network.
Some carriers don’t give a shit.
When it´s really Android 11, then I think this is based on Android 11 Go for Low Devices.
You can check this here: Android (Go edition) | Android
If it was, it would state that in the system info details :+1:
Let’s assume you want to conceal the fact that the operating system is based on Android 11 Go. Then you wouldn’t list Android 11 Go in the system information, but make sure it says Android 11. Or not?
Hello.
Can you please make a picture with WhatsApp and the Keyboard showing?
Any chance someone can help me out? I was really enjoying this watch, but now it no longer boots fully into android. I cannot find support for this device ANYWHERE.
I can’t embed media in my post (Possibly because I’m new) and I also can’t include links, but it appears to be booting into recovery mode.
There is no official support for this watch on this forum and you certainly wont find any firmware. Have you tried holding the power and lower button together until a forced reboot ?
Did you by any chance load a clockskin before your problem ? The reason i ask is some clockskins make startup slower until loaded
