Thank you very much, @Doonsbury. In fact, it was one of the most time consuming jobs I’ve ever done.
Outstanding!
Awesome work!
RK
Hi everyone,
Is it possible to use this face also, without UL ?
Thank you in advance & best regrads.
No way, sorry.
Ok,
Thank you very much for your quick answer @G1NT0N1C.
Have a great Sunday, stay safe and all the best,
Great work btw
I added the complication for the day length. Many thanks to @vladimir_lutzu. I listened to his advice and chose an annual rotation. While this means that it is only updated 12 times a year, I think this is sufficiently accurate. I will try to provide a “.watch” version with greater accuracy. The link is updated.
Do we really have to set the -14% every day ?
Today when I switched on my Prime 2, it was back to 0%. My watch is switched off during night while charging, so this will happen every day. I have remembered to press Save after adjusting the slider…
I noticed it the 1st time, because I don’t power my watch off. Will ask Eric about it.
standing ovation G1NT0N1C, clean and huge work. thanks a lot.
Thank you, @Malex! I’m glad that you like it!
first thanks @G1NT0N1C great work.
why did not work on my kospet prime with UL ?
Could you describe the problem in more detail?
as you see some faces work some not!
Ah ok, please download and install the newest UL version:
-https://drive.google.com/file/d/1sVt6etWzh7aUqFYXk5GR0tNyqXKrIPph/edit
Another way to make it work is to rename the face. Remove the both “_”.
any way of getting it to work in the right resolution with the standard launcher? i do not use UL as my launcher is used just for the watchface…everything else works with nova launcher as second launcher…i absolutly love this face but to put another launcher on my watch is a bit much…thanx…keep up the good work…
No way, sorry.
the same strange problem continues…
