Hello everyone. I would like to ask a question in here so as to get a more experienced answer. I have a Lemfo Les1 SmartWatch and I figured out how to get watch-faces on it from a website called FaceRepo . com. You can select which Face Format you want and the one I have been using is “WatchMaker”. When I do that I download what I like and it gives me a file ending with the following file extension “.Watch”. I just connect my watch to my Computer (through USB) and place the downloaded file into the “clockskin” folder and it works (I should also mention I was able to do this after installing ClockSkinCoco.apk on my watch). My question is about a different Face Format called “Facer”. The option of “Facer” has MANY more watch faces that you can install, but when you click on it to download it, you don’t get a file to save to your computer (like I mentioned above), but it brings you to a site to download it to an App (I think it’s to an App).
Do I have to install the “Facer” App on Both my Watch and my Phone, then Bluetooth Sync the watch and the phone so I can download something from the App on my Phone and sync it over to the Watch? If anyone has done that please let me know how you go about it. Thank you.
Aug 6, 2017 19:58:17 GMT 1suplex said: Hello everyone. I would like to ask a question in here so as to get a more experienced answer. I have a Lemfo Les1 SmartWatch and I figured out how to get watch-faces on it from a website called FaceRepo . com. You can select which Face Format you want and the one I have been using is “WatchMaker”. When I do that I download what I like and it gives me a file ending with the following file extension “.Watch”. I just connect my watch to my Computer (through USB) and place the downloaded file into the “clockskin” folder and it works (I should also mention I was able to do this after installing ClockSkinCoco.apk on my watch). My question is about a different Face Format called “Facer”. The option of “Facer” has MANY more watch faces that you can install, but when you click on it to download it, you don’t get a file to save to your computer (like I mentioned above), but it brings you to a site to download it to an App (I think it’s to an App).
This is an Android Wear format, so it will not work.
I thought that when I downloaded and installed “ClockSkinCoco.apk” on my Watch, it made my Watch work with Android Wear. I couldn’t even get the “WatchMaker” format (with the .Watch extension) to work before I installed ClockSkinCoco. So there isn’t anything I can do? Maybe if someone could direct me to a website that has even more “.watch” faces (like WatchMaker on FaceRepo) I could find additional faces there.
Aug 7, 2017 15:31:03 GMT 1suplex said: I thought that when I downloaded and installed "ClockSkinCoco.apk" on my Watch, it made my Watch work with Android Wear. I couldn't even get the "WatchMaker" format (with the .Watch extension) to work before I installed ClockSkinCoco. So there isn't anything I can do? Maybe if someone could direct me to a website that has even more ".watch" faces (like WatchMaker on FaceRepo) I could find additional faces there.
No you can’t do more, but watchmaker has a lot of communities on G+.
