i can´t activate the usb on mi lem7 on settings/conection/ usb apear on ligth gray, how can i turn on the usb ?, i can´t conect to my pc, any body has the same problem?
yes, the cables are not that great:/ i have to say Kospet has done great job with their watch and cables for it. if you have other cable try it, try also and see if the pins on the cable are ok and not sunk if so try pull them out a bit also check the connectors on the watch that they are cleaned.
***i am also going to upload how to put music, apps and watch faces without the need ot usb connection.
Thanks so much for your help , i try another cable and run ok ,
no i will put some music,
regards
