UPDATE FOR BAD CODING ISSUE.
UPDATE FOR BAD CODING ISSUE. ONLY AM/PM DID NOT COME OUT USING ERIC LAUNCHER 2.3.2!!
My new own version of watchfaces, TITANIUM 1.0!!
All design using Photoshop & Illustrator…
Just wait for the upcoming 2.0 version :slight_smile:
Free to download in this community but please do not re-share!!
cannot load the skin from my thor.
@Kamaluddin_Muhammad I dont know why it does not work with your Thor… but its perfect using my Lem5.
very nice skin… i like it… could somebody with thor can confirm?
Bedankt voor deze mooie clockskin :ok_hand::+1:
@Kamaluddin_Muhammad There is a subfolder in the zip. Just unpack, and copy only the subfolder to your watch.
@danny_ahmad next no double packed. Just zip the clockskinfolder. Very nice indeed. :slight_smile:
@zsolt_m I It is in the skin selection list. But when I tap to select that skin, it goes blank then default clockskin activated.
@Kamaluddin_Muhammad Have you done what I mentioned?
does not work in my LF16 with the Eric launcher. Half of the items are missing on the watch. :frowning:
@zsolt_m Yeah. I follow as mentioned but no luck. I’ll double-check. Maybe i missed something.
@Roman_Melnyk Yes… you need to use default launcher.
@Roman_Melnyk Yep, this have issue of xml coding. (bad coded elements) When you open this in CSM and save, will work in universal launcher.
@danny_ahmad Can you repair the skin, of bad coding? Yet just the X series watches can run this with this little issue, but not all.
@zsolt_m ok i’ll try if can do it or not…
@danny_ahmad just open in CSM, you will see the issue.
Great Work, thanks.
The design is great, one of the best I’ve downloaded. Thank you very much
@Kamaluddin_Muhammad can you try the new update… see if okay on your Thor…
@Roman_Melnyk already fixed the issue… you can download the new update :slight_smile:
@Luis_Martin Great you liked it… :slight_smile:
