yes i watched the video above…and i did all the same (even if this video it’s not really clear) thanks
Nope, after unboxing it you can insert a sim card and use it for calls etc. After using the “format all + download” option you will loose your imei and some other important stuff and will therefore not be able to make calls or connect to the internet trough 3g/4g…
Thanks for the update…but I gave up for now.
Right. Thx !
Dear Dr_Andy_Vishnu!
After the first battery charge, my Kospet PRIME is no longer able to initialize the system. it just loops and doesn’t reach the home screen.
This firmware version does not run on Kospet Prime.
Got another one to download?
Need your help.
Sincerely,
Leandro Vieira
This is the Kospet Prime firmware for 3+32 gb watch.
If it does not work then you have a different watch like the 1+16gb version or you have not installed the MTK drivers.
At this point I’m going to ask - why are you flashing the firmware?
As @pablo11 said you must have the right watch for this firmware to work . Not the prime SD model . Here is a little more info
https://drive.google.com/file/d/1xa7e_4byI8UrTvZ62eMj_C_YVtalB57_/view?usp=drivesdk
Tell me . Did you install a clockskin before your troubles started
Good point…
Either that or did not realise that there are different versions of the same watch and flashed just to be “up to date” and by then - too late.
