Dear Eric,
Very very thanks for your hard work for this nice and beautiful launcher.I installed this launcher today in my KOSPET PRIME SE Watch after downloading from playstore.At the first step of installation itself I opted for opening this launcher always.Also I opted for always display on .And I chose the existing third party clockskin namely ‘Audi RS 2.0 Red’.Everything in this watchface works smoothly such as phone,camera,contact etc except one thing.It is the Seconds Needle.It rotates in the Anticlockwise direction.How this can be corrected?Also one thing more whenever a message comes,the watch remains in the message screen.It doesn’t return to the Clockskin after a while.How this can also be achieved?
And lastly, whether the battery consumption will be considerably higher if Always On Display is selected?
I intend to give you a donation through paypal on finding solutions to the above questions.
Once again thanking you…
This morning I reset manually the steps count on my Prime 2 running UL. (It doesn’t reset itself…)
After a few hours working outside I got this :
The debug variable SysInc shows one big jump of 23086 steps at one time of the system steps count!
And the “fixed” steps count of 86 steps, ignoring the aberrant jump is not even correct, it should be something like 2 to 3 thousands steps.
As I never got an answer about this behavior I suppose it’s linked to the Prime 2 Firmware. (The Prime seems untouched by this bug)
But it is really weird and I don’t think it happens if you run the system launcher (Not 100% sure though).
Even weirder after quitting UL and rebooting I got this :
The steps count is the right one, 2052 steps!
I’ll check the behavior without UL for a day or two…
about the skin compatibility : some skins are done for specific launcher so on UL it can work differently.
When in AOD mode, yes the notification screen doesn’t go back automatically on the skin display. That’s an issue i’ve not worked on. As you know AOD is not recommended : it burns screens and also eat the battery quickly.
Step counter (and other things) is so weird on KP2 that i’ve no idea how to solve this. I’m waiting from some KP2 FW update to check if things get better…
Yes, I though it was that…
Here is the code that works for StepCounts in the skin I showed in my last post (Not WM LUA code obviously…)
And here is the faulty {ssc} steps counter variable in Lua :
Couldn’t you access what the Arraytype code for StepCounts takes and bypass the {ssc} variable with that in UL as a temporary fix?
BTW, With the kind of watchface that works with those Arraytype thing I never succeeded in getting the heart rate work!
Thank you Eric for the immediate reply.Accordingly I am disabling AOD.Can I correct the Anticlockwise movement of the Seconds Needle?
Also the version of UL I got from Playstore is 3.2.2.So I intend to download the latest version from this thread and install in my Kospet Prime SE afresh.For this I went to the UL Settings and clicked on ‘Uninstall this apk’.In the next page I can see the “Cancel” option only.The “Confirmation” box is on the extreme bottom right.I can’t access it in the Round screen and in the Square Screen.How can I access the “Confirmation” box? Please advise.
Waiting with Thanks Again…
Just use another skin.
About install, you can just install the new version, no need to uninstall the current one.
“The debug variable SysInc shows one big jump of 23086 steps at one time of the system steps count!”
Dominion Data Dump
I have the Audi RS 2.01 clockskin fixed to work correctly but I don’t know if I can put it here, if some moderator tells me I can put it on, I’ll put it on or if you tell me how to send it to you, I’ll send it to you.
Ok,thank you Eric.By uninstalling the present one I intended a fresh install without any remainings of data and cache of the existing one.That’s all.
I have installed Audi 2.0 Red in my Kospet Prime SE Watch.It works well with the native launcher of the watch But with UL Launcher the Seconds Needle move Anticlockwise direction.What is the difference between Audi 2.0 and Audi 2.1? However I am ready to try it.Can you post it here as an attachment if the moderator permits?Or you can pm or mail it to me .My email address is pnsdhrn@gmail.com.
Both ssc and AT12 use the same values for pedometer.
I already sent it to your email, for any questions or problems I will be here
LUA is used for scripts, not for drawing or the skin graphic itself.
Heart rate needs to be updated inside UL using the UL HR toggle (double tap and select the heart icon), i can’t read in other applications memory…
Could you please make the background of the notification all black?
Just select the high contrast option in the notification setting of UL.
G’Day Eric!
I have no idea what this conversation is about, but as it took me 25 minutes to scroll to the bottom of the post, I said to myself “Self, while your here, ya may as well do something constructive”! So I figured I’d leave you a thumbs up (
) cause it’s been a while since you got one off me and I didn’t want you to go feeling all neglected and stuff!
Cheers, Doons
How do you do that?
It is not displayed on the UL setting screen.
ok thank you
