the version 4.1 have removed the storage permission so it is no longer detected as a virus
First time I try to install itā¦
I gave up for nowā¦
you need to remove the 3.7 and clock skin transfer it should be ok, or force stop the ul and go home again it should be back to normal
HI,
sorry if question asked before, but how to remove a widget? thx.
long press the edge outside of widget
Having just decided i missed my Prime 2 (still have it just found it too big for me now) i decided to order a M99 Android watch.
Must admit i was a bit dismayed buy the lack of support now for the software until i found this.
So not much to add other than to say a massive thanks for continuing this launcher as it makes the watch so much better
Anyone else tried to install this on some Android 9 watch?
I donāt want to try it anymore by now, I was stuck on a black screen after restart the watch last time and donāt wanna pass through the same again.
android9 w527 is supported
You mean, not all Android 9 watches are supported?
Mine is Lemfo LEMPā¦.
in theory all is supported
black screen i have met once just go force stop the launcher and go home again all will be fixed
the code base from eric is a mess and all the assembly coding made it evven worse, some bugs is inevitable
so V5 of this launcher will be entirely rewritten from scratch
Sorry to ask but I really canāt find this answer anywhere.
I did far have an m99 watch and a u8 ultra with a core 5 on its way to compare them.
Everything about the ul4.1 and watch droid so far is great but I do have an issue that I just canāt solve
On the m99 I can set it to have an AOD that allows me to wake on raise back to the ul face
But the u8 does not have this so I tried to set aod with the ul settings
But on both watches I want the watch face I made with watchmaker and transferred to the watch to dim and then wake on raise.
The watch face dims ok after using the aod from within the ul settings but I cannot see any setting to wake the screen to be bright again.
I can tap the screen but I really want it to be bright on raised
So am I trying to do something thatās not possible ?
its not possible
why would you use raise to wake when you have AOD bro just choose one if you dont use AOD you can find raise to wake app in my repo
Ok Thanks
Ill take a look in the repo
The reason why if you are interested is that when outdoors the dim screen cant really be seen easy so raising to wake to bright would be really useful without the need to tap the watch.
But if its not possible then no worries thanks for the reply
but if you have raise to wake just always use that is enough no need for AOD and then you can use the raise to wake app for that
Yeah i do understand that but i find at times that the raise to wake does not always work so i like the ability to do both AOD and wake to raise just in case
But no problem ill figure out the best compromise
