Nov 5, 2017 16:26:26 GMT 1berserkmir said: I have install 2.3.5 version but not work, i use allcall w1, and is impossible to uninstall, anybody could help me to remove that?
It would be possible if you either read first post in this thread of watched video about Universal Launcher on our YT channel š
Got a problem with Universal Launcher Wallpaper thou. In my watch (KW88) i got āApp isnāt installedā notification when trying to choose live wallpaper. Watch firmware date is 20170614. Works fine on my phone.
Yes most watch FW have inhibited the wallpaper function, you need a custom ROM.
I use it everyday on my W1, so be more specific before saying that it does not work. Thanks
Ahh, I forgot that. Itās been a while since I used the watch and have forgotten a great bit
I also have a question/request. Is it possible to make a widget with the same functionality as the live wallpaper? Mayby the system handles live wallpaper better then widgets, but it would work on almost any watch/phone and launcher.
And again, thanks for your amazing work. Donation will be sent your way
Hi ricktop, sorry for off topic question(s): Are you happy with W1? AFAIK it's just the same like KW99 but has more memory and is more performant, right? Have you got any specific issues with this model? Is it possible to make "bluetooth calls" with a stock ROM? The smartphone app for W1 is still this ugly WiiWear? It would be very interesting to hear from you (as "insider") Thanks in advance!
Nov 7, 2017 15:10:28 GMT 1gregert said: I also have a question/request. Is it possible to make a widget with the same functionality as the live wallpaper? Mayby the system handles live wallpaper better then widgets, but it would work on almost any watch/phone and launcher.
Thanks for donation. Yes widget was something i did long time ago, but it works no very well because of several things : refresh rate is not good and forced low by the OS, and more than that the OS will try to disable any widget with auto refresh to save power. So Live wallpaper is much more interesting for those reasons.
Nov 6, 2017 9:59:46 GMT 1ricktop said: I use it everyday on my W1, so be more specific before saying that it does not work. Thanks
Hi ricktop , sorry for off topic question(s): Are you happy with W1? AFAIK it's just the same like KW99 but has more memory and is more performant, right? Have you got any specific issues with this model? Is it possible to make "bluetooth calls" with a stock ROM? The smartphone app for W1 is still this ugly WiiWear? It would be very interesting to hear from you (as "insider") Thanks in advance!
Yes i like to design and the straps that looks removable but are not... But battery is not very good, and one day is a maximum. Yes BT calls works, wiiwear is ugly but works ok.
, sorry for off topic question(s): Are you happy with W1? AFAIK itās just the same like KW99 but has more memory and is more performant, right? Have you got any specific issues with this model? Is it possible to make ābluetooth callsā with a stock ROM? The smartphone app for W1 is still this ugly WiiWear? It would be very interesting to hear from you (as āinsiderā) Thanks in advance!
Yes i like to design and the straps that looks removable but are not⦠But battery is not very good, and one day is a maximum. Yes BT calls works, wiiwear is ugly but works ok.
I think the problem is the watch face not the launcher. Have you tried some different faces? Iāve tested the counter with my Q7 and everything works fine no matter if the watch is power off during the day change or on.
HI! Iāve installed 2.3.5 version on X5Air and it does not ring during incoming calls when the launcher (watch clock skin) is selected. Beside that, X5Air works normally with default watch skins and its own launcher. Please, can you resolve this problem? Thx!
Nov 12, 2017 12:04:18 GMT 1drpop66 said: HI! I've installed 2.3.5 version on X5Air and it does not ring during incoming calls when the launcher (watch clock skin) is selected. Beside that, X5Air works normally with default watch skins and its own launcher. Please, can you resolve this problem? Thx!
Launcher doesnāt change sound unless you select in setting screen, so please check your system sound setting and put the launcher setting to normal.
Sucede que cuando el reloj se apaga queda pegado el skin (tambien tengo un d5+), en mi caso le doy a exit del launcher, luego ingreso nuevamente y reseteo el skinā¦
Hi there, my name is Alex, I came here just to say thank you for your work on this launcher, it works perfectly on DM 368 itās pretty cool. I just have one question, itās there a way to have the back button working different? I mean, when Iām inside any application from play store and I push back button it turns off the screen instead of sending me back to home screen, in this case to the clock itself. Thanks a lot again, I loved your work
Nov 14, 2017 8:25:32 GMT 1a7exandroj said: Hi there, my name is Alex, I came here just to say thank you for your work on this launcher, it works perfectly on DM 368 it's pretty cool. I just have one question, it's there a way to have the back button working different? I mean, when I'm inside any application from play store and I push back button it turns off the screen instead of sending me back to home screen, in this case to the clock itself. Thanks a lot again, I loved your work
Strange, only HOME button will do that, the back button works normally (at least on my watches)... So, no i don't think i can do anything...
First of all thank you for the great work!
I have just installed the app. I do not have a lot of time to read all of the questions and answers here so,
Can we choose all watch. files? Locked ones? Where can we easily find unlocked ones?
One of the main complaints that I have had with my stock zeblaze thor rom is that there is no way to get rid of the lock symbol when you turn your wrist. Here you can BUT as far as I understand you can have it turned on for no more that 10 seconds. When you reach that number even if you scroll down to find an app to launch it turns off. Really annoying. Am I missing something?
