Ulysse Nardin El Toro
work in progress…
https://www.ulysse-nardin.com/
The bigest problem is that the two bottom disks are for two last digits of the year. I am thinking how to make them work in our watches. Any ideas?
work in progress…
when I would to made that, I made as array.Each number one rotate circle. sample for you, this is not perfect, just you can see how its work… https://drive.google.com/file/d/0B5zdgfaDe7FEV1gwcmNPQ0xFQU0/view?usp=sharing
@zsolt_m Thanks! I have some ideas but it’s good to listen to experienced designers
But there is also problem that each digit of a year must be separate array and some parts of these arrays must be hidden…
@Jacek_Klodzinski just look at my sample…
@zsolt_m Downloaded and checked… It works! Thanks again - I will use your solution in the final watch face.
@zsolt_m I’ve tried to download your example but it’s not available now, can you share it again please? Do that solution works on WFD? THANKS!
@Toni_Cabrera_Ceballo link still working.
@zsolt_m Now yes, before it said to me that file had been sent to recycle bin by the owner. Thanks!
Hehe… I not touched that…
Google Drive wanted to play, XD
