D5+ w613, how can i Root ?
hello, i`ve tried to flash twrp on my finow x5 plus and now it is bricked. i tried to flash stock rom with sp-flash tool but nothing work. I dont have adb access,too
Please help me
What TWRP did you used on X5+?
Flashing the stock ROM, without the preloader, will always restore the correct behaviour, there is no way to brick the watch following this simple rule.
is this applicable for THOR?
Yes, it is
Hello, I downloaded the package when doing the update of a zebelze thor smart watch and everything has turned out perfect in fact I did not have to install the drivers thanks for your help
Sept 11, 2016 6:21:32 GMT 1 RASC Moderators said:
All Devices Core Tools and Root Pack v5 04/10/16 (link)link doesn’t work …
Please help me, How to re-flashing X01 (square) smartwatch, because screen resolution changed so touch is not works.
we do'nt have support for this watch, you can try here:https://plus.google.com/u/0/communities/118413074291213420811
basically you need the stock Firmware use this video on how to flash:
Thanks for the post.
Can you help me what is the suitable TWRP recovery, Tools and Root Pack for Finow X5 air on Lollipop 5.1, MTK 6580.
Thank you
drsaidalavi
Dec 14, 2017 19:37:07 GMT 1 drsaidalavi said:
Thanks for the post.Can you help me what is the suitable TWRP recovery, Tools and Root Pack for Finow X5 air on Lollipop 5.1, MTK 6580.
Thank you
drsaidalavi
i'll check for you:)
Thank you
drsaidalavi
Thank You, waiting for your reply
Dec 15, 2017 8:23:30 GMT 1 drsaidalavi said:Dec 14, 2017 19:44:04 GMT 1 soniasophie9697 said:
i’ll check for you:)
/thread/1016/twrp-recovery-port-x5-lem5
be careful to follow the rules and do’nt do nothing if you’re not sure ask plz ask before:)
All Devices Core Tools and Root Pack v5 04/10/16 (link) TWRP 2.8.2.0 Custom Recovery for (X1/D5/X3/K9) by Ciro Danise (link) TWRP 2.8.2.0 Custom Recovery for (X5) by Ciro Danise (link)right link for the root:
drive.google.com/file/d/0B3xyOuab2f-OQWE3WU0yUTc4YkU/view
LINK FIXED PERMANENTLY!! goo.gl/1kHSm8 tools v5
Core Tools now contains TWRP and needed files for all the watches we support. So, one zip, all devices.
Hello,Can be this used to root Finow X5 air also.Kindly replydrsaidalavi
Dec 17, 2017 17:17:15 GMT 1 drsaidalavi said:Sept 11, 2016 6:21:32 GMT 1 RASC Moderators said:
follow Ciro instructions
Thanks for the reply, but in that forum he is not specific about Finow X5 Air on the latest firmware. So I am afraid to flash the TWRP. When I asked the question , is this TWRP is compatible with X5 AIr, no reply come yet. So kindly help me whether I can flaxh TWRP for Finow X5 plus
Thanking You
drsaidalavi
the root of the no1 d5plus w613 android 5.1 works now
if so please which files, or which way
Thank for Answer
Try to root my Les1,
folloed these steps:
1- Inside the Core Tools and Root Pack found HERE, copy the UPDATE-SuperSU-v2.46.zip to the watch.
2- Launch SPTool.
3- Click on “Scatter Loading”
4- In the next window, select your device
5- Click on the “Download” button.
6- Long press the power button on the watch and turn it off.
7- You will get a device connection sound and SPTool should start flashing TWRP. When it finishes you get a big green check mark popup on your PC.
8- Turn on the watch and go to Settings > About > Developer Options and enable USB Debugging
9- Launch MTKdroidTools.exe located in the MTK Toolbox folder.
10 - You will get a popup on the watch about authorizing your PC, check that and allow.
11- In MTKdroid Tools, click the “Reboot” button in the bottom right corner.
12- On the popup, select “…recovery”
13- The watch will reboot into TWRP recovery
14- In TWRP, tap “Install” and select the UPDATE-SuperSU-v2.46.zip
15- Reboot
16- Congrats! You are rooted!
I can’t proceed step 11 because the “Reboot” Button is GRAY
(I got the popup on my watch and allowed authorizing)
(Flashed the TWRP with the “recovery-twrp-302-LES1.img”)
What seems to be the problem ?
I installed TWRP on X5, but how do I open TWRP?
Hello,
For a zeblaze thor 4 (MTK6739) I have to use what?
SP flash tools
My watch is blocked after the start on a black screen
thanks for the help
