TWRP, Tools and Root Pack
All Devices Core Tools and Root Pack v5 04/10/16 (link)
TWRP 2.8.2.0 Custom Recovery for (X1/D5/X3/K9) by Ciro Danise (link)
TWRP 2.8.2.0 Custom Recovery for (X5) by Ciro Danise (link)
right link for the root:
drive.google.com/file/d/0B3xyOuab2f-OQWE3WU0yUTc4YkU/view
LINK FIXED PERMANENTLY!!  goo.gl/1kHSm8   tools v5
Core Tools now contains TWRP and needed files for all the watches we support. So, one zip, all devices.
Core Tools and Root Pack v3 02/10/16 released
Change Log
1- TWRP and root for all Classic and current Plus series watches
Classic Series- D5, K9, K8 Mini, K18 Mini, K8 Round, K18 Round, X1, X3, X5, Q3
Plus Series- D5+, X1+, X3+
2- SPTools updated to v5.16.36
This applies to Kingwear KW88?
Lets see;
1- Posted in the D5, X series, Plus series & Atenea section
2- Description specifically states
“TWRP and root for all Classic and current Plus series watches
Plus Series- D5+, X1+, X3+”
Core Tools and Root Pack v4 03/10/16 released
Change Log
1- Replaced MTK Toolbox with a modded more compatible version
2- Added Universal ADB installer
Core Tools and Root Pack v5 04/10/16 released
Change Log
1- Core tools pack now contains TWRP and needed files for all the watches we support.
Someone already root in Finow x3+?
Yes, you can use the rooting the proper way thread. Probably need to turn off drive signature verification on Win 8 and Win 10 for the Mediatek driver to install properly.
/thread/30/rooting-proper
X5 drivers and tool cannot find it please someone help!!??
EVERYTHING you need is in the all tools zip. It is the exact same tools I personally use for every watch you can find in this forum.
I downloaded this twice " All Devices Core Tools and Root Pack v5 04/10/16 (link) " but still unable to unzip it. something broken and the files in it look like duplicates.
Please assist on getting these files available
Just downloaded to test it. Zip file is fine. Suggestion: download 7-zip and unzip using it. Unizipped is 244 MB
Yea.. I'm using 7zip too. Will try again..
LINK for TWRP 2.8.2.0 Custom Recovery for (X5) by Ciro Danise (link)is not working?
i have to use this for X3+ also right?
thanks!
All the available recovery images are in the All Tools zip.
Has anyone rooted the x3 + after installing all OTA updates?
When installing the recovery it gives me error the application of cardiac pulse.
I’ve tried twice and it always happens.
When I install the first update in December, it happens to me.
With the first two updates installed does not happen.
What about TWRP for X5+ (W616)? Is there any already built?
Ciro Danise Could you make it, please?
I don’t have an X5+ so the best I can do it’s to use the X5+ boot image to build the TWRP recovery with it, but I can’t I test it.
I’m sorry but this is not the proper way to work for me.
I can test it I’ll be grateful if you will build and send me a link.
When i put the scatter file it only check the recovery section, i’m not able to check any other one (x5 file on lemfo lem5)
