TWRP for Wisp (X02S/X01S Plus MT6580)
Team Win Recovery Project 3.x, or twrp3 for short, is a custom recovery built with ease of use and customization in mind. It’s a fully touch driven user interface no more volume rocker or power buttons to mash. The GUI is also fully XML driven and completely theme-able. You can change just about every aspect of the look and feel.
Downloads/Source Code:
TWRP Image Download: 3.2.2-0
TWRP Image Installer Download: 3.2.2-0
Scatter file: Here
TWRP Source Code: Here
Kernel Source Code: Prebuilt Stock Kernel
Install Instructions:
If you have TWRP installed already:
  1. Download the first link which is just the twrp image files
  2. Copy the image file to your watch
  3. Boot into twrp
  4. Click install
  5. Click install image
  6. Navigate to the twrp image you copied over and select it
  7. Find recovery in the list and select it
  8. Swipe to confirm
  9. You’re done
If you don’t have TWRP installed:
  1. With your watch turned on, copy the file “TWRP_patcher.zip” to the /sdcard directory.
  2. Turn off your watch.
  3. Open sp flash tool
  4. In the “Scatter-loading File” box choose the “MT6580_Android_scatter.txt” file that you downloaded
  5. Press on “Download”.
  6. Connect the watch to the computer.
  7. Connect the watch to the computer and wait until a green tick appears on the screen.
  8. Unplug your watch and power it on
WARNING: the following step (9) will install the default boot.img for the stock rom of the device. If you have another rom installed, be sure to flash it after finishing this guide.
  1. On the recovery, go to Install -> Install Zip and select the previously copied file “TWRP_patcher.zip”
  2. Wait until it finishes and that’s it!
Boots to twrp, but cant mount data on my x02s. Let me know if you need more info. Thanks
