Team Win Recovery Project 3.x, or twrp3 for short, is a custom recovery built with ease of use and customization in mind. It’s a fully touch driven user interface no more volume rocker or power buttons to mash. The GUI is also fully XML driven and completely theme-able. You can change just about every aspect of the look and feel.
Downloads/Source Code:
TWRP Image Download: 3.2.2-0
Scatter file: Here
TWRP Source Code: Here
Kernel Source Code: Here
Install Instructions:
If you have TWRP installed already:
Download the first link which is just the twrp image files
Copy the image file to your watch
Boot into twrp
Click install
Click install image
Navigate to the twrp image you copied over and select it
Find recovery in the list and select it
Swipe to confirm
You’re done
If you don’t have TWRP installed:
Turn off your watch.
Open sp flash tool
In the “Scatter-loading File” box choose the “MT6580_Android_scatter.txt” file that you downloaded
Press on “Download”.
Connect the watch to the computer and wait until a green tick appears on the screen.
Unplug your watch and power it on
Once it boots plug your watch and do
adb reboot recovery
