Team Win Recovery Project 3.x, or twrp3 for short, is a custom recovery built with ease of use and customization in mind. It’s a fully touch driven user interface no more volume rocker or power buttons to mash. The GUI is also fully XML driven and completely theme-able. You can change just about every aspect of the look and feel.
Download the first link which is just the twrp image files
Copy the image file to your watch
Boot into twrp
Click install
Click install image
Navigate to the twrp image you copied over and select it
Find recovery in the list and select it
Swipe to confirm
You’re done
If you don’t have TWRP installed:
With your watch turned on, copy the file “TWRP_patcher.zip” to the /sdcard directory.
Turn off your watch.
Open sp flash tool
In the “Scatter-loading File” box choose the “MT6580_Android_scatter.txt” file that you downloaded
Press on “Download”.
Connect the watch to the computer.
Connect the watch to the computer and wait until a green tick appears on the screen.
Unplug your watch and power it on
WARNING: the following step (9) will install the default boot.img for the stock rom of the device. If you have another rom installed, be sure to flash it after finishing this guide.
On the recovery, go to Install -> Install Zip and select the previously copied file “TWRP_patcher.zip”
Nov 18, 2018 4:40:34 GMT 1deadman96385 said: Team Win Recovery Project 3.x, or twrp3 for short, is a custom recovery built with ease of use and customization in mind. It's a fully touch driven user interface no more volume rocker or power buttons to mash. The GUI is also fully XML driven and completely theme-able. You can change just about every aspect of the look and feel.
Boot into twrp
Click install
Click install image
Swipe to confirm
You’re done
Open sp flash tool
Wait until it finishes and that’s it!
I've the TWRP for Microwear H2 Second Generation since half of October. Ya, it's antiharmony and works very well. 2 pieces of advices:
flash ONLY RECOVERY.IMG file and not BOOT.IMG so no need to install any boot patcher
first boot into TWRP ( from ADB), rename the script INSTALL-REVOCERY.SH in INSTALL-RECOVERY.whatuwant in folder /SYSTEM/ETC in order to avoit TWRP overwriting — or in alternative — flash SUPERSU before first booting into system
