@Di_Di I am on 1.1.6 as well.
I have tested 1.5 for a short time. Some downloaded faces are not working with this version. So i go back to 1.1
Thanks @Di_Di . I did the test and same in here. With the 1.1.1, the battery level works perfectly. With 1.1.6, it does not. I have finally installed the launcher v1.1.6 and the Stand Alone App v2.0.1. and depending on the face I want to use, I am swtiching between these two… Maybe not the ideal solution, but it allows me to have all the faces working one way or the other. @Eric_Crochemore Do you think it is the right way to handle these little comptibility issues that we encounter once in while with such or such face and such or such version of your fantastic tool ?
HI @Di_Di I’ve tried once to make such a thing
https://plus.google.com/115115648060107962550/posts/NWDSPDC2GFv
https://plus.google.com/115115648060107962550/posts/TP5kepKTKim
Wow ! Very nice faces @mouradOo_ned . Even if some spinning wheels are not displayed correctly on my KW88 running @Eric_Crochemore launcher v1.1.6 or stand alone app v2.0.1, I am totally impressed by the way you managed to get such realistic moves for the pistons/springs. The combination of your work for the pistons and @Di_Di 's skills for the green liquid would create the most realistic HYT face we could dream about… Many thanks to the three of you.
Thanks mourad0o,
Your face is great!
It shows perfekt the mechanicle working!
Yours is great too
@Di_Di and @mouradOo_ned Please work together and create the perfect one that should be a mix of each of yours !!!
this is great!
This watch is indeed awesome, but, because of the software updates (perhaps…) of the KingWear88 nine months later, this october 2017, it makes the KW88 literally freeze. And so, no damages, but after less dans a minute, I have a black screen, I push the button two times, and then I am back with the KW88 watch faces. And so, I can navigate through all of my watch faces without any problems. In the end, I had to remove this jaw dropping watch from my KW88. :))
I couldn’t use this face, when I installed it seems like the file is corrupted or lite @Thierry_Berton said, is a problem about updates…
only one word ! GREAT
