Tiny square screen, need magnifier
Hi all,
Sorry for this but I have been trawling the boards looking for this info and cannot find it. Can someone please tell me how to change from round to square screen mode, and also how to zoom/drag/move when in an app (not just an image, but actual apps).
I’m trying to use Google Fit on my Kospet Hope but I cannot read the words and my fingers or stylus are inaccurate when pressing corner buttons.
The only other problem I’m having is figuring out how to go between open apps without them closing each time. Is this possible? I’m unsure…!
Kevin
streetcarxxx
  1. long press the power button and the upper one is to change from square to round display:) the white one.
  2. use google gesture to search accessibility to get zoom and magnification also search in this app font and you can resize the font size.
play.google.com/store/apps/details?id=com.google.android.apps.gesturesearch
or
www.apkmirror.com/apk/google-inc/gesture-search/gesture-search-2-1-5-2-release/gesture-search-2-1-5-2-android-apk-download/
Apr 2, 2019 16:18:48 GMT 2 soniasophie9697 said:streetcarxxx
or
Thanks soniasophie9697
The screen shape works but the google gesture has been deleted from Google Play, so I’ve downloaded it using APKmirror. All very new to me so thanks for your help.
can use three tap magnification as well
say ok google
accessibility then activate three tap magnification when u tap your screen 3 times it goes into magnification mode
must set up ok google first ofc
say ok google
kospet hope doesn’t have accessibility option. The assistant shows info for the normal android phone.
it has I did it yesterday ok google say accessibility magnification three taps done
just tried it again  worked  perfectly  ok google       open accessibility      you’ll  see magnification gesture    three  tap
… just to add, once you get magnification turned on, it takes two finger touch to scroll while magnified. It can be cumbersome but it does work. Also, if you don’t use Google Assistant, the app QuickShortCut Maker(https://play.google.com/store/apps/details?id=com.sika524.android.quickshortcut) can help you with accessing the Accessibility Menu.
search settings apk download does do the job as well
Excellent I am on the way again, thank you for that.
Now I just need it to do the vibrate prompts / sedentary prompts and things to remind me to move and walk and when I’m close to my step goal yadda yadda. Am experimenting with google fit app and Fitbit app. Any suggestions welcome.
:space_invader:
