I see you can buy a battery. Has anyone actually tried getting there’s apart?
Yeah, it’s not too difficult at all.
Most important thing is to be careful when you put it together again.
The rear cover can crack if you overtighten the screws.
That is incredibly helpful thank you.
It is surprisingly easy to remove the rear cover.
Bear in mind that the straps and cover come off as one piece.
If you are thinking of buying a battery - make sure it is made for the DM101.
Otherwise you will have issues with getting the connector from the original battery to attach to the new battery. It’s a painful process if the connectors are not exactly the same.
