Turn off watch and charge to 100% not 99% ( make sure turned off ) - Your battery reading will never be true ! The only way you truly know it is at 100% is when it says so and you have charged it much longer than required ( ie overnight ) . I can charge mine to 100% then leave overnight switched off , put back on charge and battery 56% ? .
Delete the two apps ( clear cache / app data first )
Look in your wifi settings ( make sure that all sections in advanced are unchecked ( A Section In Here Can Be Turned On Without You Knowing When You Use GPS and can stay on even after you have turn GPS off - If battery drain returns keep checking this )
In uninstall apps section look at all the google stuff ( playstore / location / maps etc ) . Clear ALL data / cache and ignore warnings ( dont worry about this ) . Do not delete these apps ! . If battery drain returns do this again .Keep doing the usual stuff like closing apps after use / keep bluetooth , wifi , gps off unless using them .
I also turned off auto sync on GMail although i only did this as a precaution .
All of the above i find will give me upto 24 hours battery depending on watch face i use ( some use a lot more battery than others )
My daily settings for the above results are :-
Erics Launcher
Bluetooth off
Wifi off
Gps off
Hand raise on
Screen 50%
I hope this helps everyone as it has helped me . Would love to hear your results .
play.google.com/ Store / apps / details? Id = com.newagetools.batcalibra
Spegni l’orologio e carica al 100% non 99% (assicuratevi spento) - La lettura della batteria non sarà mai vero! L’unico modo in cui lo sai è al 100% quando si dice così e lo hai pagato molto più a lungo del necessario (cioè durante la notte). Posso addebitare la mia al 100% poi lasciare la notte spenta, ripristinare la carica e la batteria del 56%? . Tutto quanto sopra trovai mi darà fino a 24 ore di batteria a seconda della faccia da guardare io uso (alcuni usano molto più batteria di altri) Le mie impostazioni quotidiane per i risultati di cui sopra sono: - Erics Launcher Bluetooth off Wifi disattivato Gps off mano aumento Screen 50% Spero che questo aiuti tutti come mi ha aiutato. Mi piacerebbe sentire i tuoi risultati. Cordiali saluti Vishnu Grazie al dottor Tony Bunn e Nameless Mi piacerebbe sentire i tuoi risultati. Cordiali saluti Vishnu Grazie al dottor Tony Bunn e Nameless Mi piacerebbe sentire i tuoi risultati. Cordiali saluti Vishnu Grazie al dottor Tony Bunn e Nameless
I want to follow your suggestion on my les1, but the first link does not work.
Thanks Doc, I’ve tried this guide. My d7 was barely survive 5 hours, its improved to 1% / 9 minutes or about 15 hours battery life, everything is off except Bluetooth and watchdroid. But prior to these procedures, i’ve disabled all google’s app, and haven’t delete the 2 battery apps that you’ve mentioned just wondering if i repeat these procedures will I get better an better results?
To be honest this post is so old it was more relevant with older watches that was available then . I dont recall it being any better if you ran the process over and over again . I’m unsure what a D7 watch is . Is it a old A5 watch ?
