Hello. Newbie ask.
Yesterday i get my new watch. Then I trying to check all functions.
Now I have this problem that I don’t know,how I can activate the step counter.
I was long time in the city, but the watch shows not 1 step.
How i can controll the step counter from menu Fitness-outdoor walk -go.
Time and heart BPM running.
Is perhaps the watch defective?
It’s a fake watch?
Other problem. I can not find the sleep monnitoring in the watch. In the description was written - supporting.
Sleep monitoring is for me also very important.
Thank you for helping
You can test with the “MTK Engineering Mode” app: play.google.com/store/apps/details?id=com.themonsterit.EngineerStarter&hl=en
- Open the app
- Select “MTK Settings”
- Scroll to the right to the “Hardware Testing” menu
- Select Sensor Hub Test
- Select STEP_COUNTER
- Switch on STEP_COUNTER
- Click “CLEAR CURRENT TRIP” button
- Start walking and check the counter at the bottom of the page
Hallo, maybe its enough to go to settings, gesture, aktivate pedomerter
Feb 15, 2019 2:50:31 GMT mangkulas said:
Yeah, that was what iandhope answered to your question.
Did you want to say something, like the provided solution worked just fine?
Really, when you delete your post leaving an empty page with a quote, you don’t have to press the Post button, just press CTRL+W and magic will happen.
Many thanks. It was really disable. I enabled it and it work. Thank you.
But it work only when I walk and swing the hand about 50cm horizontal. When I walk without swinging by the hands, it not counting.Is not really a pedometer and I can also not find the step whithe. Important, it work.
Feb 15, 2019 6:57:11 GMT mangkulas said:
2. Select "MTK Settings"
I come only until point 2. Then it comes notice ...entry developer option in setting. In settings I can not find it.
You must enable developer settings: Settings - About Watch - scroll down to Build number and keep tapping on it until developer options are enabled
I found it, but it shows the steps when in gestures the pedometer as active is. Thank for this tip.
