Oct 26, 2016 19:45:10 GMT 1 eviltrooper said:
Does it works with the iqi i2?
THIS but with the widget version beta is what I’m testing right now.
Oct 26, 2016 15:44:20 GMT 1 RASC Moderators said:
For the widget, Hidden persistent notification would be away around that, another might be administrator rights permissions. Beyond the widget locking up issue, the only unlisted issue I noticed scaling is different depending on the watch and how it scales the launcher. I think this is more a ppi issue. I'll update this post with some pics, or maybe a video.Either way, face creation is far easier than the apk method and open up over 300 usable faces for the KW/I2/Clones. The only suggestion I can make is make face changing a long press, tap to change is the same reason why my Urbane LTE running Wear 2.0 is sitting in a drawer.
Eric, please reply if you can make zoom in Skinclock 1.2 in two clicks (instead of pushing)? I would be very grateful.
Excellent! Eric, you are the best of the best of the best!!! )
Hi Ricktop , can you add a version with swipe right open M2d receiver? to read notifications faster? Thanks for you nice work!!
There’s a launcher project that uses this engine, but doing that on this one would be going in the launcher path. I just want it to be a standalone for the moment. Anyway i keep that in mind.
Hi,is it possible to zoom in -out manually after double tap,and not with preset sizes?Thanks.
Normaly, the auto scaling should be enough in most cases, could you provide a picture of your problem with your HW specs so that i Can see why you’d want that feature ? Thanks
No,there isn’t a problem, works excellent. I just wanted to “modify” some watchfaces by hiding few mm from their outer diameter.Rings etc.
Oct 31, 2016 9:11:55 GMT 1 bathman said:
No,there isn't a problem, works excellent. I just wanted to "modify" some watchfaces by hiding few mm from their outer diameter.Rings etc.
Ok i see, i keep that in mind.
can you post the tutorial again ? link is broken.
This is fit on LEM3 Watch ?
Nov 23, 2016 16:12:53 GMT 1 narsa said:
can you post the tutorial again ? link is broken.This is fit on LEM3 Watch ?
Link is still correct. Another tutorial is probably in this forum also.
Hello Eric…
it seems that this does not work properly (nothing is displayed) :
<drawable>
<colorarray>ff0000,000000</colorarray>
<arraytype>15</arraytype>
</drawable>
ArrayType 15 is “special second” that can be seen in “ClockSkinP8”
(the seconds appear one by one as red squares in the first minut, then desapear one by one in the second minut… and so on.)
Any idea how this works ?
How if more than two values in the array ?
Picture Link : drive.google.com/open?id=0B-BXQ_dj4sgRX1lwTGtJVDRuSkk
Full Skin Link : drive.google.com/open?id=0B-BXQ_dj4sgRSjJ3TndSc0RxelU
Dec 14, 2016 9:26:39 GMT 1 rolandtanguy said:
Hello Eric…it seems that this does not work properly (nothing is displayed) :
<drawable> <colorarray>ff0000,000000</colorarray> <arraytype>15</arraytype> </drawable>
(the seconds appear one by one as red squares in the first minut, then desapear one by one in the second minut… and so on.)Any idea how this works ?
How if more than two values in the array ?Picture Link : drive.google.com/open?id=0B-BXQ_dj4sgRX1lwTGtJVDRuSkk
Dec 16, 2016 15:41:19 GMT 1 akiloff said:
Hi Master! Help council! How to return the APK file to ordinary archive (zip) for ClockSkin? It is possible? Thanks!
Don’t understand the question.
Hello there! Thanks a lot for this… Only way to change watch faces on KW88… BUT! The scale is wrong And not centered. Even on the demo face. Do you know why? And how to fix it? Thanks.
Dec 24, 2016 13:35:31 GMT 1 fredbest said:
Hello there! Thanks a lot for this... Only way to change watch faces on KW88... BUT! The scale is wrong :-) And not centered. Even on the demo face. Do you know why? And how to fix it? Thanks.
Have you tested 1.1 version in the new thread ?
How to connect smartwatch to my computer? I’m still confuse about the tutorial. Thankyou
Amazing work, my kw88 is loading all the clock skins properly using you program, i am software developer what is the logic you are using, if i want to fix in xml file then what should I do? Thanks
