Seems like zeblaze is releasing new watch series with nougat rom. Can anyone port it to old zeblaze thor?
Can we use it just like previous method of flashing if chipset is same?
That will probably not work, if it were that easy then we would have already lots of people running nougat on their watchesÂ
I have run Nougat on my DM368. Only issue is inverted and touch axis also inverted. Apart from that everything is working perfectly. I just need some good port for DM368 HEHUI. I will try to find a way to make it work. BTW nougat is good. Battery timing is better than before.
