Smart watch with BT calling and In-built Speaker
Hi Members,
Can someone suggest me the best android watch as per my requirements below
  1. BT calling : Should be able to receive/answer/dial calls directly from the watch when connected to my Phone through BT
  2. 3G/4G SIM support & WIFI: Should be able to function as a fully stand alone watchPhone
  3. In-built Loud speaker : For Music play back and to answer calls
  4. Minimum 1GB RAM and 4GB ROM (Memory card support optional)
  5. Battery Back up : Atleast for a full day with Data ON
  6. Preferably Android as i would like to download & listen to music streaming apps from Playstore
  7. Multiple watch faces support
  8. Fitness sensors & apps : Not necessarily needed but good to have
I already own a KW88Pro which is neat except for the horrible batt back up and missing BT calling feature, so looking out for other options.
the only one which i tried and answer all your specs is the H2 from microwear.
Ok Thanks, will check out
Hi Sophie,
I have checked out the above watch and though the features looks promising , its a bit out of my budget and seems to be costly than the rest in the same segment. So can you suggest any other make meeting the same criteria …
My top priority is BT calling and In-built speaker for music playback followed by good batt life of alteast 24 hours
sathyak
the H2 is under the 100USD but you might want to check also the thor pro but it is’nt as good as the H2 in 5.1 watches this is the best sadly it is’nt waterproof but so far i have’nt heard any other users who had this issue.
also you might want to check the i4 air, thor s, thor , the les1, i3…
www.aliexpress.com/af/5.1-smart-watch.html?SearchText=5.1+smart+watch&d=y&initiative_id=SB_20181110042405&origin=n&catId=0&isViewCP=y&jump=afs
Nov 10, 2018 13:27:27 GMT 1 soniasophie9697 said:sathyak
Hi Sonia,
Kindly excuse for troubling you again but can you once again suggest the best watch with my modified requirements as listed below:
  1. BT calling : Should be able to receive/answer/dial calls directly from the watch when connected to my Phone through BT and lag free
    and no connection drops
  2. In-built Loud speaker : For Music play back and to answer calls
  3. Minimum 512 MB RAM and > 4GB ROM (Memory card support optional), hopefully lag free navigation
  4. Battery Back up : Enough juice to support online streaming music for a minimum of 2 to 3 hours
  5. 3G/4G SIM support : Should be able to receive & answer calls via sim independent of the phone
  6. Edge to Edge display similar to Lemfo watches with very minimum bezel
    -If possible but not mandatory but atleast greater than 1.39"
  • able to support Eric’s Launcher
  1. Fitness sensors & apps : Not necessarily needed but good to have
Thanks in advance
    and no connection drops - only android 5 watches fupport this feature as the  i4air, H2, kw88, kw99, kw98, zeblaze thor.
  2. In-built Loud speaker : For Music play back and to answer calls - all watches.
  3. Minimum 512 MB RAM and > 4GB ROM (Memory card support optional), hopefully lag free navigation - all watches:)
  4. Battery Back up : Enough juice to support online streaming music for a minimum of 2 to 3 hours - that is hard as most watches i’ve never used just the kw99 and the H2 so the H2 is the better choice.
  5. 3G/4G SIM support : Should be able to receive & answer calls via sim independent of the phone android 5 watches have only 3g capability and 4g (lte) capablitiy only android 7 have it.
    -If possible but not mandatory but atleast greater than 1.39" - the H2
  • able to support Eric’s Launcher - all watches.
  1. Fitness sensors & apps : Not necessarily needed but good to have - all watches.
Super … i have also almost zeroed on H2 based on your feedback …and if possible , can you suggest a good seller on ali express for this watch please?
Dec 11, 2018 12:49:16 GMT 1 sathyak said:
Super .. i have also almost zeroed on H2 based on your feedback ..and if possible , can you suggest a good seller on ali express for this watch please?
it is better to wait and ask ppl about the i4 air (@cpatjon) the thor\les1 (pycon) which also are considered great watches my usage with the H2 was limited to few days before it died because of corrosion that happened as i workout everyday for few hours, the time it worked it was great but dying after few days is a big issue i'm not saying that yours will be the same just can't be sure.
I checked both these watches i4 air and les1 …they are equally good
except that they are having lesser batt compared to H2. I own a KW88Pro which is ossom except for that very low batt back up of just 2.5 to 3 hours when 3G is ON and thats really very frustrating for daily usage , hence looking for options.
I am thinking to keep this one for my work out sessions and then use H2 for casual daily wear …
I am also open for square watches if any one does meet my requirements above… and also can wait for 2019 just in case if you have any idea any new releases are planned for the new year
Thanks Sonia
Dec 12, 2018 9:18:02 GMT 1 sathyak said:
i know that there are going to be from Zeblaze and Kingwear but most likely after the holidays of christmas, that is the only downside of the kw88pro and the kw68 which the battery capacity is very small for daily usage.
Ok, worth the wait then… Will try to adjust with my pro for now… Thanks
sathyak
sadly i have customs issue with the arriving of th ekw88pro so i still have’nt gotten it but to get more time with the watch using sim disable anything that use backround data, in settings go to more and there just disable any usage of data with apps that you do’nt need that they run all the time like google play store, google services, when you need upates do them manually, disable syncing…also use Google Gesture to make sure that nothing uses 3g data as long as you do’nt need them.
Yeah, I have been doing the same, installed Greenify which has now boosted the backup time… With no BT, wifi or 3g,and by turning off the wrist raise, then atleast it lasts for about 1 and half day… But during my workout sessions, if i stream online music, then its hardly an hour before the batt dies…
Hopefully awaiting for the new releases shall support BT calling…
