Hi, do you have any idea where or in what smartwatch settings I need to look to unlock the pin code of a SIM card so that it don’t have to ask for it every time I close and open the smartwatch?
If I remember right, you have to use a mobile phone for this. Put the card in a mobile, disable SIM PIN and put it back in your watch.
Thanks for the reply. However, it would not be possible with the application ‘‘copy of settings search’’ apk
I just had a look. On Kospet Prime it’s possible to do it with setting search. Security- Sim-lock disable.
Thank you very much. I will try with the apk and if it doesn’t work I will use the first method indicated by you. Thank you again!
It work with Apk! Thank you!
