Seiko Macchina Sportiva by Guigliaro
(Request by Calebe)
Credits: http://www.italdesign.it/project/macchina-sportiva/
Download: https://drive.google.com/open?id=0B3tgeBO1P6rVVVd0ZEE3Yk5MWGM
Made only using Watchface Designer 0.7.2. (Thanks mpmf)
Not 100% accurate but pretty close i think
Made the blue clocks a bit bigger to make it easier to read.
Everything works on a KW88.
Very nice, fine work…I ready downloaded it, thank you!
Love the color and simplicity of this watchface. Installed on I4 Air. Everything works except the day dial is always one day in advance. Watch is correct and all other faces read correctly. Can this be fixed?
Thanks.
@Jonathan_Bickel I will take a look at it.
@Jonathan_Bickel Fixed the day dial. Just check the new download link.
@Bert_van_de_Bovenkamp just uploaded it works like a champ. I see where you rotated the dial? Thanks a bunch.
I noticed after another charging cycle that the Battery Gauge reads backward? Example. There is 10% currently remaining and it is at 90%. Is it reflecting the amount remaining or amount used?
@Jonathan_Bickel I will take a look a that too.
This is one of my earlier watchfaces, in the later ones i already tackled those issues.
