Sedentary alarm on KW99
Hi All,
on some of the specification from a different webpages it says that KW99 has got a sedentary alarm? So far I’ve not found a way how to set it up?
Can anyone confirm if it’s got one and how to set it up please?
Thank you,
Jan 26, 2018 12:44:27 GMT 1 tomasg said:
Hi All, on some of the specification from a different webpages it says that KW99 has got a sedentary alarm? So far I've not found a way how to set it up? Can anyone confirm if it's got one and how to set it up please?
Thank you,
do you mean alarm clock? if so, yes, i use it with my kw99.
No I mean the alarm that detects that you’ve been sitting (or in standstill position, not moved)for long time and alert you that you should make some move.
no, it does'nt, i think there are apps for that but most likely drains battery.
ricktop
