my 2c of everything i tried and failed at. maybe someone can prove us wrong. really dwarfs your options with the watch. everything that needs access goes through the enable disable of the list. the only way i can see getting around this is waiting for a ota update and hoping they fix it, maybe a rollback to a older update (never tested), or getting it rooted (haven’t seen a way yet).
150 crashed it here using a diffrent launcher… mix matching options, size + density + overscan + standard or zoomed. all failed with no way to enable slider
tried every adb way i could think of
screencasting just shows screen nothing more
Had the same problem using tasker and no solution. Also I can´t change the theme in the gboard settings, because the button is too far right (damn custom layouts!)
May 12, 2017 15:37:11 GMT 1chromax said: Had the same problem using tasker and no solution. Also I can´t change the theme in the gboard settings, because the button is too far right (damn custom layouts!)
Mine doesn’t have accessibilty menu, wondering where is the accessibility menu hidden? Firmware March,22 2017, just looking for an apk which can direct me to accessibility menu
Install an automation app of your choice that can handle locale plugin (tasker, llama, e-robot, etc.).
Install Secure Settings (search for it in play store).
In the automation app, make a command to use:
Locale plugin > Secure Settings > System+ action > accessibility service > choose your app and toggle en/disable > save.
May 13, 2017 21:54:15 GMT 1maxilimian said: Mine doesn't have accessibilty menu, wondering where is the accessibility menu hidden? Firmware March,22 2017, just looking for an apk which can direct me to accessibility menu
May 13, 2017 21:54:15 GMT 1maxilimian said: Mine doesn’t have accessibilty menu, wondering where is the accessibility menu hidden? Firmware March,22 2017, just looking for an apk which can direct me to accessibility menu
Hi all, I don’t want to root my watch X5+ but I want to customize the buttons with simple apps such as Button Mapper or Buttons Remapper.
Because X5+ has 3 buttons, this would be a great feature to associate for example “ok google” command to one, or EasyTouch.
This is quite simple, but the crazy screen issue is blocking any customization!
I tried so many tricks but I’m not getting a way out…
Any other suggestion?
May 25, 2017 7:54:11 GMT 1zorro said: Hi all, I don't want to root my watch X5+ but I want to customize the buttons with simple apps such as Button Mapper or Buttons Remapper.
Because X5+ has 3 buttons, this would be a great feature to associate for example "ok google" command to one, or EasyTouch.
I’m using home button app, this app can bring you to the watch screen instantly, a great & simple apps, perfect combining with circular side apps, if you want to go back just do a finger swap
I already have a software button, I want to customize the hardware buttons.
Another crazy thing is that I cannot automatically sync Google account and every other messenger because I cannot reach the buttons to activate them!
Telegram, Facebook Messenger, the contacts and so on… are updating data only when I open them!
I’m the only one in this situation?
