Hello everyone, Bonjour à tous
I treated myself to a dm 20 because finally after the lem 14 I prefer the rectangular screen. But I have a
little problem =):
how to adjust the screen to the right size??? thank you very much
I seem to remember that you could switch between round mode and square mode, even though it wasn’t a round watch. Press and hold the power button to check.
thanks, but no ! sorry =)
I wonder if you can enable Developer Options. Try to touch several times your Build Number in your information section at Settings
Otherwise the app “settings search” might work:
-Copy of Settings Search-com.katzoft.settings.search.full-1-v1.0.apk - Google Drive
Konntest Du das Problem lösen?
thank you all I tried everything nothing works
Idea: try connecting to computer (enable ADB in developer settings), and run:
adb shell wm density 160 (for example)
Try a few different densities, this will have the effect of reducing the size of the dialogue box, and hopefully bring the button into view.
Bon courage !
