All of you running open watch rom or just searching for good screen resizer
apkpure.com/screen-shift/com.sagar.screenshift2
I use this on several devices, let you resize, change dpi and much more.
Oct 23, 2018 2:09:35 GMT 1 seb84 said:
root needed im sure
you are forgeting you have the knowledge that most do’nt:) i’m not sure it is good idea for ppl to change something and might not be able to change back if they’ve made a mistake.
it has an auto recovery function, means, that the change (resize, resolution change etc.) has to be accepted after it was applied, or the program will automatically switch back to the old setting, therefore it should be extremely safe to use.
Root is needed.
First I decided to test on the old tablet.
I have installed Easy DPI Changer on my rooted FINOW Q7 Plus and everything works great on DPI 100 but my watch faces are bigger… I can’t see edges of face… Any solution?
Nov 20, 2018 13:22:58 GMT 1 ktl20 said:
I have installed Easy DPI Changer on my rooted FINOW Q7 Plus and everything works great on DPI 100 but my watch faces are bigger.. I can't see edges of face... Any solution?
doens’t it give you the choice to do it for each apk?
you can try to run a small tasker command set for this i think.
just use home as action, to resize to normal
Hey, is there such app but without root?
Old thread I know.
The windows manager of Android can do this without root
If you have adb shell prompt use this:
wm size
wm overscan
I like to set my round watch like this: wm overscan 5,15,5,15
