Hi
My S1 smartwatch cant turn on. I have only pic of watch on screen and then black screen. It started that green led was turn on non stopand when I tried to reset my watch this happend:/ Any one know how to solve this?
Jul 31, 2018 13:50:57 GMT 1 ktl20 said:
Hi My S1 smartwatch cant turn on. I have only pic of watch on screen and then black screen. It started that green led was turn on non stopand when I tried to reset my watch this happend:/ Any one know how to solve this?
Flash the watch, if it hardware problem it will continue to happen
Where to get firmware for this watch? Do You have formware for this model (S1 plus) to flash it with SPFT?
it is the same as the q7+ you can flash it just use upgrade on firmware and do'nt mark preloader (if it let you).
When I plug watch to usb it dont charge battery is empty and after some time the screen goes black and shows empty battery again and its over and over…do You think flashing will help? I have empty battery
Jul 31, 2018 17:38:05 GMT 1 ktl20 said:
When I plug watch to usb it dont charge battery is empty and after some time the screen goes black and shows empty battery again and its over and over...do You think flashing will help? I have empty battery
you do'nt need the watch on to flash but if it is hardware problem then flashing wo'nt help but only if you flash you'll know.
Flashing didn’t help:-/ any suggestions? Is that hardware problem? I’ve bought this smart watch month ago
Aug 2, 2018 17:50:20 GMT 1 ktl20 said:
Flashing didn't help:-/ any suggestions? Is that hardware problem? I've bought this smart watch month ago :-(
if flashing went well and you still having problems that means hardware, i know:/ i had 4 s1 till i understand i was stupid, finow started to make bad watches and that is why now most ppl do'nt touch their watches even the software and updates they release are crap and the joke they do'nt even want to work with our developers which contributed alot to the improvement of the watches over the years. my suggestion is to wait till the developers team will make custom roms and it might work for your watch.
btw, which firmware did you flash?
I flashed w637_wgl.q7plus.common.80.Emma.w.s.170913.flash …so there is a chance for resurrection of my watch?
When I plug my watch to USB I only have this (pic) zapodaj.net/3b6f1ebe87cda.jpg.html and after a while black screen and then again battery
that sounds more a cable problem, do you have spare one?
No I don’t:-/ problem starts when I had my watch on hand and I noticed that green led is shining then I restarted watch and then.I couldn’t turn it back on…the led was on and on screen i had picture of watch and nothing more…my battery get down smart watch was heating a lot and when I back home I couldn’t charge it back and it shows me like.on pic. Flashing with this cable is ok.
There is video ufile.io/614w6
In my eyes the battery is dead.
Maybe you right because now when.I plug 2A charger to my watch I have Finow logo for a while and the rest is the same
Is there a way to check or repair this alone? Is that normal that after few days the battery got dead? Any chance for repair ? Is it worth?
Is there something else I can try to get it work?
Aug 7, 2018 8:16:57 GMT 1 ktl20 said:
Is there a way to check or repair this alone? Is that normal that after few days the battery got dead? Any chance for repair ? Is it worth? Is there something else I can try to get it work?
let see:
1.flashing - should fix any software issue that causes battery problems
- if it is’nt software then you need to replace the battery.
my suggestion is to contact the seller who you bought from and ask for full refund or replacement.
I get back my watch from GSM service and guy didn’t know what’s wrong he told me that battery is fully charged and he has no idea what’s wrong…it’s strange that when.I plug the watch to power supply it only shows empty battery for a while and then black screen sometimes finow logo …maybe others have some more ideas? I want to repair this watch if.it’s possible because refund is not an option now.
Aug 13, 2018 20:09:54 GMT 1 ktl20 said:
the only solution i can have for you is to replace the battery with new one but that is not for sure could be the problem, try first this let it charge and then when it reaches 100% turn it on and plug it again to charger till it shows you again 100% and from now on if it works do'nt let it shut down when it reaches 15% plug it to charger and leave it till it reaches 100% see if this help if not then replace the battery but again if flashing did'nt work that mean it is'nt software solution.
Can someone can give me battery model of this watch?
