Someone has rooted his KW88 ?
What do i need. TWRP version ? What soft on your PC?
Can you discribe?
Thanks folks
Can you discribe?
Thanks folks
Dec 10, 2016 9:49:30 GMT 1 hdf4800 said:
Someone has rooted his KW88 ?What do i need. TWRP version ? What soft on your PC?
Can you discribe?
Thanks folks
I think kingoroot PC version works.
By the way what do you want to do with root?
Can you discribe?
Thanks folks
Is update with OTA with rooted kw88, after rooting with Kingroot app?
Dec 10, 2016 14:29:58 GMT 1 janek said:Dec 10, 2016 9:49:30 GMT 1 hdf4800 said:
Can you discribe?
Thanks folks
No need PC. I rooted my KW88 with apk version of kingroot.
Thanks for the infos, I personaly have to recalibrate the battery… It stays up for 1 day but it powers off at 53%… Just a calibration issue but it gets on my nerve :@ !
Question : If after the calibration I unroot, would I receive the OTA updates ?
Dec 14, 2016 17:13:55 GMT 1 linuxma said:
Thanks for the infos, I personaly have to recalibrate the battery… It stays up for 1 day but it powers off at 53%… Just a calibration issue but it gets on my nerve :@ !Question : If after the calibration I unroot, would I receive the OTA updates ?
Jack
Jan 5, 2017 13:16:02 GMT 1 jackster said:Dec 14, 2016 17:13:55 GMT 1 linuxma said:
Hi My kw88 does exactly the same shuts down 50% what calibration app do you use (not rooted)Cheers
Jack
kingroot doesn’t work in both apk and pc version!is there any other way?
Jan 7, 2017 15:49:59 GMT 1 gtamark said:
kingroot doesn't work in both apk and pc version!is there any other way?
Install a taskmanager and see the CPU usage, if kinguser eat much cpu then then install com.kingroot.kinguser_4.0.2.apk
Jan 7, 2017 16:56:57 GMT 1 janek said:Jan 7, 2017 15:49:59 GMT 1 gtamark said:
Kinroot apk can root the KW88 but it's not easy. Download the root.zip from here drive.google.com/open?id=0B1dzhoZphb9VQ0htLVRubXQ3d0U 1st. Install NewKingrootV4.9.6.apk and run if reboot then run again and again while not say cannot root. 2nd. Install kingroot4-8-2.apk and run while it say rooted.Install a taskmanager and see the CPU usage, if kinguser eat much cpu then then install com.kingroot.kinguser_4.0.2.apk
Jan 8, 2017 1:18:29 GMT 1 gtamark said:Jan 7, 2017 16:56:57 GMT 1 janek said:
why latest version doesn’t work?
My Firmware version is KW88_20161215.
Rooting with this version works completly.
Now you can install apps who need root access.
Hope will work for other firmware versions did not test other firmware.
tried the following and work neither on my Kw88 nor S99 watches…
