Try to root my Les1,
folloed these steps:
1- Inside the Core Tools and Root Pack found HERE, copy the UPDATE-SuperSU-v2.46.zip to the watch.
2- Launch SPTool.
3- Click on “Scatter Loading”
4- In the next window, select your device
5- Click on the “Download” button.
6- Long press the power button on the watch and turn it off.
7- You will get a device connection sound and SPTool should start flashing TWRP. When it finishes you get a big green check mark popup on your PC.
8- Turn on the watch and go to Settings > About > Developer Options and enable USB Debugging
9- Launch MTKdroidTools.exe located in the MTK Toolbox folder.
10 - You will get a popup on the watch about authorizing your PC, check that and allow.
11- In MTKdroid Tools, click the “Reboot” button in the bottom right corner.
12- On the popup, select “…recovery”
13- The watch will reboot into TWRP recovery
14- In TWRP, tap “Install” and select the UPDATE-SuperSU-v2.46.zip
15- Reboot
16- Congrats! You are rooted!
I can’t proceed step 11 because the “Reboot” Button is GRAY (The device isn’t revealed)
(I got the popup on my watch and allowed authorizing)
(Flashed the TWRP with the “recovery-twrp-302-LES1.img”)
What seems to be the problem ?
