Rom y3 with Watch droid and Bluetooth call?
If is possibile,can anyone do a custom rom where Bluetooth manager is Watch droid and where is possibile male Bluetooth call?
I am a newbie.
Watch droid is the only app which work between my Nexus 6p and y3 smartwatch.
But unfortunately notifications appear only if you open the app on the smartwatch or when you are just coming because the default app is WiiWare.
Can someone solve this problem?
Nov 3, 2017 17:25:38 GMT 1 got74 said:
If is possibile,can anyone do a custom rom where Bluetooth manager is Watch droid and where is possibile male Bluetooth call? I am a newbie. Watch droid is the only app which work between my Nexus 6p and y3 smartwatch. But unfortunately notifications appear only if you open the app on the smartwatch or when you are just coming because the default app is WiiWare. Can someone solve this problem? Thanks
as long as the wiiwear is disabled or deleted from your phone Watch Droid should work fine and with no problems, BT calls do'nt think be possible with the app.
but if there are no more upgrades and nobody does a rom with new firmware, how can this become a watch that works?
good question, but sorry do'nt have an answer,  maybe you can use different FW on this watch.
pablo11
nameless
good question, but sorry do’nt have an answer, maybe you can use different FW on this watch.
pablo11
nameless
Whath different firmware i can use?
pablo11
nameless
i'm not sure, the specs of your watch is the same as the kw88 so it might be the one, plz wait till one of the developers will reply:)
Ok thanks
