I can’t even go 2 meters away without it disconnecting!
My phone is fine, I use Bluetooth speakers that can go up to 15 m easily.
Assuming this is a software issue, has anyone had this problem? If so, what did you do to fix it?
Thanks in advance
Thanks in advance
The range on your phone will be considerably better than a small watch with smaller hardware . I’ll be honest i have used with earbuds only with no issues
