I have got a kw 88 watch…when I try to connect bluetooth with my android phone it is getting paired but in the watch where I scroll from top to bottom in which there is a screen that sows red x mark in bluetooth which I not able to connect with wiiwear. Further iam also not able to connect with android wear app. I have several time reset the equipment.
Nov 6, 2017 0:30:07 GMT 1harry said: I have got a kw 88 watch..when I try to connect bluetooth with my android phone it is getting paired but in the watch where I scroll from top to bottom in which there is a screen that sows red x mark in bluetooth which I not able to connect with wiiwear. Further iam also not able to connect with android wear app. I have several time reset the equipment.
I need help
Have u tried using the “watch droid phone” and the “watch droid assistant” apps?
I need help
it is’nt an android Wear watch so you can’t use the Wear app. i do’nt see much different if it is red or green i had the s99a which is simillar to the kw in software and i got green all the time but no functionality to it i found. as was recommended above me it is better to use Watch Droid or M2D which give you more then the stock wiiwear\wiiwatch. you can reply to most apps and the connection is always stable. with M2D you can use it with BT, wifi and 3g.
hey sophie as mentioned in the earlier post iam having a kw88 smartwatch… you will be aware that now we can bluetooth calling using this smart watch. I was following your video. can i use the same procedure for my firmware upgrade. if yes can you post a seperate link for the all that is required becos iam not able to find those links in this forum or i dont know how to find the links that you have said in the video. are those links compatible for windows 10 pc.
open sp f.tool and go to scatter loading file - locate the txt. file and select it and everything should be uploaded.
3.choose firmware upgrade and press download
turn off the watch and connect it to your pc and flashing should start if not disconnect and reconnect the watch should’nt start charging if so disconnect and reconnect till you see that it start flashing and at the end of the process you should see a green v mark. that’s it:)
hi friends… i recently brought a new apple iphone 8plus. I face bluetooth connection issues. In my phone under the bluetooth settings it is shown as kw88 connected. in the watch in bluetooth phone call settings it shows connected with iphone. iam unable to synchronize my phone book or contacts. Further i also downloaded wiiwatch app from the app store. in that wiiwatch app under device management iam unable to find my watch name. Please help me. If any body can post detailed video on fixing this issue it will be helpful. not able to receive any notifications. need help
Jan 22, 2018 20:55:03 GMT 1harry said: hi friends.. i recently brought a new apple iphone 8plus. I face bluetooth connection issues. In my phone under the bluetooth settings it is shown as kw88 connected. in the watch in bluetooth phone call settings it shows connected with iphone. iam unable to synchronize my phone book or contacts. Further i also downloaded wiiwatch app from the app store. in that wiiwatch app under device management iam unable to find my watch name. Please help me. If any body can post detailed video on fixing this issue it will be helpful. not able to receive any notifications. need help
with the previous phone did it work? was it iphone?
Jan 23, 2018 18:32:21 GMT 1harry said: further please also let me know if i do a factory reset will my latest firmware upgrade will remain or go back to the oldest firmware.
no, the firmware wo'nt change to it's previous version.
i was just wondering. i tried to do the firmware update to my kW 88 for the BT feature. i went to get the firmware off of the thread that Pablo had posted. but once it was downloaded on my computer an error message came up and stated that the file was sent in through an email and must be damaged, because it could not be read. i tried to use the micro app that would convert it. but could not find it on my computer once it was finished downloading, in any scatter file to download into the spflash tool. please let me know that there is another firmware to use. because that site that i used is asking my to purchase that particular one. please help me. thanks, ta.
Jan 25, 2018 6:51:09 GMT 1tbird1227 said: i was just wondering. i tried to do the firmware update to my kW 88 for the BT feature. i went to get the firmware off of the thread that Pablo had posted. but once it was downloaded on my computer an error message came up and stated that the file was sent in through an email and must be damaged, because it could not be read. i tried to use the micro app that would convert it. but could not find it on my computer once it was finished downloading, in any scatter file to download into the spflash tool. please let me know that there is another firmware to use. because that site that i used is asking my to purchase that particular one. please help me. thanks, ta.
Have you tried downloading on different pc? Or even to your phone? I had no problems with the download via chrome, if you have antivirus try disable it.
I will try tonight again. The mega site that uploads it on to the computer says that I have reach my max of uploada/ converts and states my trial is up and to purchase some optional plan. That is why I am asking if there is another site or sites that are free that are to be used in order to down load the firmware on to my computer. I think once I get it downloaded correctly it will show up in a folder on my computer and thus the splash tool will help me once I have the scatter file showing up. I know that this seems easy. But to someone that does not mess that much with downloading on to a computer that much it is not.i guess there will never be and OTA update for the BT. Unless you purchase a new watch that has it already installed. Thanks for the help and hope to continue to get your help.
witam, jestem tu nowy i nie mogę znalezc rozwiazania swojego problemu. Moj zegarek to GW-10, z tego co patrzyłem na specyfikacje to jest taka jak niektore kw88 i pare innych. Nie działa mi prawidłowo Bluetooth. Czy moge uaktualnic oprogramowanie ktoraś wersją z kw88? Nie widze zadnego wsparcia konkretnie do GW-10, a osprzet ma taki jak GOLDENSPIKE kw88u. Blagam o pomoc!!!
Feb 4, 2018 22:17:22 GMT 1kosi said: witam, jestem tu nowy i nie mogę znalezc rozwiazania swojego problemu. Moj zegarek to GW-10, z tego co patrzyłem na specyfikacje to jest taka jak niektore kw88 i pare innych. Nie działa mi prawidłowo Bluetooth. Czy moge uaktualnic oprogramowanie ktoraś wersją z kw88? Nie widze zadnego wsparcia konkretnie do GW-10, a osprzet ma taki jak GOLDENSPIKE kw88u. Blagam o pomoc!!!
no, this watch is'nt as the kw88 and if you flash it with it's firmware you'll brick the watch. sorry but i do'nt think any of the firmware we have suits this watch.
I’m sorry, but if there is no way to change the firmware then maybe someone knows how to fix the bluetooth problem?
The watch with the phone can be seen and paired, but you can not connect them … ;-(
I was looking for solutions, but I can not find ;-(
