Reeboot Finow Q3 without start button
Hi everyone. I am having a problem with my Q3. I can not reeboot from start button. Somebody knows, how cant i restart my watch without start button? Thank you so much.
you have problem with the button? install app for shortcuts which give you also the option to reboot the watch BUT i think that you'll need root or at least a custom recovery to have this option. but you can check in google play store just write reboot or quick restart.
Thanks Sonia. It is working again, i used a little of brute force.
you have problem with the button? install app for shortcuts which give you also the option to reboot the watch BUT i think that you’ll need root or at least a custom recovery to have this option. but you can check in google play store just write reboot or quick restart.
what is weird it also happened to me with the Q7 but now it is ok.
Another thing. Do you have stock rom for Q7? I read that smartwatch has android 5.1, and i would like to try to port to my watch. Could you help me?
if you know the model of the watch i can see what i can do, you can't flash any rom because it can brick for good the watch.
Yes, I know. My watch Q3 and your watch Q7 have the same chipset (MTK6572). I read a tutorial and i would like to try do it. The Q7 has similar specs than Q3. I did it a firmware update with CM12.1 custom rom for Atenea, but my watch has a dotted screen, and once it show me a flipped screen without screen touch. Also, i did a port with CM12.1 but it doesn´t work, my watch had the same android version.
if you know the model of the watch i can see what i can do, you can’t flash any rom because it can brick for good the watch.
still not the same model: mine is w626 and yours is for sure other model, do'nt forget they have also different displays sizes and resolutions.
