Recovery LEMFO LF17
Maybe someone could help me, I bought one LF17 on tomtop.com and I idiotically blocked it with the “secondary screens” option .
So my watch is unusable until I do a factory reset, but I can’t access successfully to the recovery by booting the watch. I obviously forgot to enable USB debugging so I can’t use abd reboot recovery.
If someone know how to access to recovery mode.
Thanks !
Mar 25, 2018 21:11:27 GMT 1 vince35 said:
Maybe someone could help me, I bought one LF17 on tomtop.com and I idiotically blocked it with the "secondary screens" option .
Thanks !
long press till you feel two vibrations on the watch, but not sure it will help you cos the recovery is very basic and you can’t do much from there.
Thanks for your response, but when I turn on my watch there is no vibration and if I hold the button the watch reboot.
Are you able to loading a firmware on it? I think I have one for LF17 or you could als check here on the board
I don’t know how to install a new firmware, but if you have one it would be cool. Do I need a special software on my computer to install it ?
Thanks for your responses, I finally succeeded a factory reset with the google service, luckily Wifi was enabled and I was able to command an erasure of presonal data. Now the first option I’ve changed is ‘enable debbuging’ !
Here is the link to the FW:
mega.nz/#!geQ1nAoB!h1iYlYnm0IIcy_iKA9kpxD9oZkqv2WERxr9-7vH51C4
unmark the preload for flashing.
Sorry, how i can install this firmware? I mean which program do i need and if i need change something on my mobile? i can’t open any app on my watch and bluetooth not working good. Sorry my english, i’m from Argentina. Thanks!
Update: I download sp flash tool but when i try to download firmwarer it appears “chip type not match - target type is mt6580 loader scatter chip type is mt6572” how can i download for my correct chip? Thanks again
